s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Thu Jul 07, 2005 3:22 pm
its a tossup bro. it really just depends on how bent your car is and where. i have one 240 that is at stock ride height and wont adjust into spec with those worthless eccentrics. plus, the eccentrics are easily damaged by incorrect adjustment(aka impact guns). if your car is lowered it just makes it that much less likely to go into spec. what you can do is have them get it as close as you can and drive it. then you decide if you want more or less of something. alignment is more important than ride height and almost as important as tire compound.
here is a good(laymans terms) alignment setting for performance
fronttoe just a hair of toe incamber -1.5caster +7.5 or more if you can get more
reartoe just a hair of toe incamber -1.0
now keep in mind your stock stuff is only adjustable for toe(front and rear) and camber(just rear).
