ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Thu Feb 10, 2005 4:20 pm
I got the below from a thread that was here before...================================Camber: Front -0 degrees 51' (+- 45')Rear -1 degree 5' (+- 45')
Caster: Front 6 degrees 50' (+- 45')Rear - no adjustment
Kingpin angle: Front 13 degress 25'Rear - no adjustment
Toe-in (mm): Front 0.8 (+- 1)Rear 2.5 (+- 2.5)
One side toe-in angle (Front & Rear) - no adjustment
Side slip value (mm): Front (In 5 / Out 5)Rear (In 5 / Out 5)
The ticks after the degrees are minutes, just in case you didn't know. I have no idea what "one side toe-in" is. Maybe it's the rear forward link if you have adjustable units. I believe the kingpin angle refers to the tie rod END heights if you had adjustable units (i.e. SPL parts).
