Ok guys,
I am familiar with the tramlining issues. I have a 11' ex35 awd and it has 19" continentals on it and i am getting a tramlining issue. It was much much worse but took it to sears to get an alighment. The sears i originally went to had an older alignment rack and they said they could try to get it close but it would be best to go to a newer sears. Either way the first time fixed much of the problem because it was nearly out of control when ruts got into the road.
I took it to a sears on the other side of town and they touched it up and again a little better. The problem and question i have is camber issue. The front left is -1.4* on the left front and -0.10 on the left rear. The FIRST guy at sears said that there is no more ajustment left in the camber. The SECOND sears i went to said that they are not ajustable. Either way, the fact remains that the left front camber is way out and the right front is nearly perfect or slightly to the + side.
What do i do?
Thanks!
