ALERT (nissantouge87)
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
I purchased 444GTR injectors from this guy a few months back and just got a replacement ECU from him in the last week or so. (60 bucks for jectors+ 45 for the ECU)
had the ECU tuned for said 444 injectors by jestr tuning + other mods with eprom. shelled out 200 bucks for all their tuning and sodering services.
today after tons of guessing what the issue was and checking a million things to figure out what the issue was. I re-installed my stock injectors and magicly the same thing happened agian with the tuned ECU + stock ECU.
turns out the Coding on the side of the injectors turns out to be th exact same numbers so my stock 370(IIRC) injectors and the ones sold as 444 injectors are infact the same.
did anyone else have issues with the things he sold? I did not know I was going to be sent broken injector caps either........
what is the best course of action? I paided 200 bucks for a tuned ECU that now does me no good without the proper injectors. I spend 60 bucks on something that does me ABSOLUTELY NOTHING . I also now cant even return him my good stock ECU as the other one is currently tuned
I hope to hear from him soon and will compose a detailed msg to him in the morning but looking for a bit of feedback right now as to what others think is a good chocie to do first?
Ps very sad I spent part of my BFs birthday, easter, and my weekend off only to be very let down and feel very scamed.
mbmbmb23
Are the "444cc" injectors the same color as the 370cc's? The 444's should be yellow tops. Good news is ebay has dsm 450cc injectors for $40-$50 all day long that will work.
-m
ca18detgabby
03 Infiniti G35
ca18detgabby
03 Infiniti G35
the 444s looked identical. I didnt even think about them being different just figured nissan used the same outer shells with different guts.........
much like all the other parts that are on the different S-chassis(s) and engines.
ca18detgabby
03 Infiniti G35
now if Im to go wit the 450 injectors.......... I need to retune for 450s instead of 444s?
sorry not used to tuning w/o a screw driver
mbmbmb23
450cc and 444cc can use the same tuned ecu.....just make sure you get low impedance DSM injectors (all DSM should be low). The OEM eclipse 450's are blue top or black top. You will need to use the CA's lower o-ring insulators on them tho.
-m
ca18detgabby
03 Infiniti G35
Thats some good news
themadscientist
I have a set of 444s if you are interested.
ca18detgabby
03 Infiniti G35
how much. being that my ECU was tuned for them I would much perfer to stay in tune than going up inside and running a little rich .
themadscientist
$120 shipped. They have been cleaned and flow tested by RC Engineering. Here is the test results for them which I will include.
They have not been used since the service was done. Anything else you need, I love cleaning house.
ca18detgabby
03 Infiniti G35
SOON as I figure out what Im going to do with him I will send ya some cash.
NissanTouge87
Car: 1992 CA18 S13 hatch, 1992 pignose nissan pickup
hey, sorry about the confusion on the 444s..there are multiple reasons i thought they were 444cc injectors.
1: detailed writeup on boostcruisin.com showed his 444cc injectors and they looked the same as mine
2: car barely, and i mean barely ran with them in there, switched to 390cc injectors and lowered my fuel pressure according to Float_6969's suggestions and the car ran 10X better
if need be i will refund the money because i dont want some confusion on my part to ruin anything.
As for the pintle caps another guy i sold injectors to had the same problem, and i KNOW when i shipped them out the caps were perfect. Again a shipping error on my part.
I have no problem refunding the money because that should not have happend and it is my fault. How is the ECU and coilpacks doing?
Either E-mail me, PM me, or AIM me and we can get this taken care of.
Sorry about the confusion/troublesEric
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
if Gabby doesnt buy the injectors i call dibbs
themadscientist
NissanTouge87 wrote:hey, sorry about the confusion on the 444s..there are multiple reasons i thought they were 444cc injectors.
Both parties keep us updated on this please.
NissanTouge87
ill be sure to, like i said, it was never intentional that this happened, and id like to keep her happy because she bought most of my stuff, and i also no what its like to try to get a CA running..haha
but yea, if anyone else had any problems with the products i sent out, lemme know and ill see what i can do
ca18detgabby
03 Infiniti G35
like I said I couldnt even run the ECU as it was running so lean the car actually desieled of sort and kept chocking to try and turn with the battery removed and I had to actually pinch the gas line to finally shut her down all the way. it was real ugly. I would image you had it tuned for 444s and were running the 390s and had the same issue I experienced.
if you could refund the money and I can pick up TMS set we will be set. I havent swapped the coil packs, but I can check them out if you want me to.
Im assuming the ECU is good as the it did the same thing with both sets of stock Injectors........ w/o flinching. will have to wait and see I suppose.
NissanTouge87
yea, i can give you the money for the injectors back.
i didnt have anything tuned on my CA, all stock everything, i couldnt figure out the sputtering problem which could have been the dropping resistor and vac leaks. so i just said screw it and went megasquirt. Kinda the cheap way out, but i was going to anyways..so
ill be paypalling the money shortly
ca18detgabby
03 Infiniti G35
themadscientist wrote:$120 shipped. They have been cleaned and flow tested by RC Engineering. Here is the test results for them which I will include.
can you send an invoice to [email protected] for those please sir
yourmomsrps13
Gabby what turbo are you running? i have a good friend who does ECU tuning/soldering
ca18detgabby
03 Infiniti G35
right now I have my stock CA T25
I have BB T28 in the garage a waiting a cleaning(probably just rebuild it for reliability purposes............ got to love $40 turbos right?)
jt15833
Car: 95' 240SX
tms ever sell the injectors? I will take if not.
themadscientist
I think Gabby wants them and then another member got in line if she doesn't want them.
Dam I need to organize. I went to grab the set I was offering Gabby and there is a second set of 444s that I forgot I had! These are NOT cleaned however, they are as is but look great.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Want to send me one of those r30s?
themadscientist
bag of rust flakes you cover shipping.
r34 gtr
How many rust flakes are we talking about? I'm game if its somewhere in the range of 2800lbs and resembles a bada$s RS skyline.
themadscientist
Just for you. Let me show you what you are asking for.
r34 gtr
...That raises the question...why do you still have that?
I kinda want one in slightly better condition. Tell you what, in 6 years when the r32 is exempt from inspections and stuff, I will come scare your family and we will go find me one, in exchange for me leaving your country forever.
ca18detgabby
03 Infiniti G35
just think of all the potential cars you could save from future mishaps if he left the country. "will someone please think of the children"-simpsons
lol I kid I kid.
yes please I WANT!
PS how much work is it to get one of those R30s state side? Im sorry they are hot as hell. even that one rusted to ****.
themadscientist
Hard to find here, next to impossible there. I own half of them.
ca18detgabby
03 Infiniti G35
themadscientist wrote:Hard to find here, next to impossible there. I own half of them.
its ok I just want those injectors. maybe one day I will have my RB30E S13
