WD will an A/F Gauge or EGT gauge still work n help with tuning?
IMO, tuning with A/F Gauge or EGT gauge is one of the worst idea. A/F gauge don't show accurate A/F ratio. EGT only tell combusion temperature, won't tell you lean or rich. ( can be either )
When comes to tuning, you seriously need a WB sensor. Or you can spend $50 for dyno run.
You can build your own Wide-Band O2 sensor for $200 or less.
http://www.diy-wb.com
Question for WD:-How's the A/F ratio react when you start spraying alcohol ?-On your previous post, you meantion MSD knock sensor safe you few times on very hot day. If you maintain constant 11-12:1 a/f, will that still happen ?-You also mention 13:1 a/f produce wonder power output. I am wondering if that apply alcohol usage?-Did you say Alky has more energy rating than gasoline ?-How you think about Toluene ?
