If you're gonna go that route, put 3 relay switches in place that require a specific combination of open/close to allow for starting and be done.PoorManQ45 wrote:Yeah, I know what you're saying, But as you will soon learn, I am PoorManQ45. I like to do things myself for less then it would cost to buy an already built kit.
I personally would combine a starter kill switch will a seperate fuel pump cutoff and hide the switches in seperate locations so that if one is found, the car still won't run.
That's too complicated, I can't remember what I had for breakfast and you expect me to remember the order to flip switches?Rex wrote:
That's the thing, I am talking about only electrical cutoffs. You wouldn't actually cut the fuel supply, you would just cut the power to the fuel pump.Rex wrote:I'd rather mess with strictly eletrical, than fuel and eletrical.
And it would cut off???PoorManQ45 wrote:... That's the thing, I am talking about only electrical cutoffs. You wouldn't actually cut the fuel supply, you would just cut the power to the fuel pump.
Oh sorry, I thought you were thinking that we were talking about an actual valve to cut off the fuel.. Oops.Rex wrote:
Therefore, you would in effect be messing with the "fuel", I'd rather just stop the spark. Yes, this could result in a soaked/flooded condition, but (my guess) they aren't gonna try that long, if it never turns over/starts.
aight i dunno what just happened buut... ok thats exactly what i have been wanting to do but wasn't sure if it was possible! i like the way you think rex! can you explain a little more how that would work? thanksRex wrote:
Sorry, I had stayed away fromt his thread in general .Hellion240sx wrote:whenever your ready rex
What type of circuits and relays would you have to use to get that kind of effect?Rex wrote:Sorry, I had stayed away fromt his thread in general .
If you think about each switch either being open or closed, lets use pluses and minuses for example the switches could be in the following positions
- - -- - +- + -+ - -- + ++ + -+ - +etc with only +++ allowing the car to start. You would just have to know the right sequence. Keep in minid these three switches could be located at various points of the car.
Just put them "in-line" in any circuit that is required to start the car. It could be bewteen the key tumbler/ignition adn the starter for instance.PoorManQ45 wrote:What type of circuits and relays would you have to use to get that kind of effect?
I mean, what I got from what you said is basically you're going to be putting in three seperate switchs, that's it. Could you extrapolate a little bit please?
