alarm ticking
tek1792
Car: 1992 nisan 240sx
so i have evrything in my car accept but the horns. so as i decide that to try and start the car and nothing. i get a ticking noise out of the fuse box infront of the drivers side. when i try to turn the car on it turns into a ding. i call the local nissan dealer and they said it sounded like a security king thing. i was wondering if i could bypass this somehow or if there are any sloutions to the problem.
johnny butt
Car: 1993 240sx Convertible
what the f*** are you talking about?
240sx doesn't come with an alarm from the factory.
What brand alarm was installed aftermarket and where was it installed?
tek1792
sorry about the title thats me being a dumb a$$. its just a faint tick if i put the key in the ignition. then when i try to start the car it turns into a ding from inside the car and the little red lightbulb on the steering column flashes. any idea?
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
ummm, well do u know if the previous owner put an alarm in the car? a pic of the light that flashes? you wont get any help with the small amount of info you provided bro
Dazzla
disconnect your battery for 5 minutes, then plug it back in and that should reset the alarm and your car will start up...this is common with s*** aftermarket alarms, and im in the process of ripping mine out
nismoracingsx
Car: 1993 White 240sx Coupe
Yup, cheap alarm, uninstall that junky junk :)
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Most (not all) aftermarket security systems actually power up in an alarmed state which means that if you disconnect the battery and then reconnect it, the alarm will trigger causing the parking lights to flash and siren to sound. I'm only guessing but it sounds like your siren has been removed or cut and the battery is dead but has enough power to power the security system so the relay clicking is the parking light relay "flashing" and when you turn the key to start the car, every ounce of power is being sucked out of the battery in an attempt to start the car so in effect, power is being removed from the alarm. When you stop trying to start the car, there is enough power to energize the alarm and it wakes up in an alarmed state which makes the relay clicking sound because the brain is flashing the parking lights. Most alarms have two main fuses near the brain. The lower rated fuse (5A) is usually the main power. Remove the fuse and see if the clicking stops. The car still may not start if the battery is dead.
dccse3k
Are you talking about the bell in the shift lock unit below the driver dash? its a green box and you could tear into it and remove it but i believe it dings when you have the key in your car and it is all the way ccw.
