Alarm
modQ45
Car: cars
I need help again my alarm got armed at work and I do not have the remote for the original alarm. To make matters worse I dont have keys for the door locks or the trunk. My key only starts the car and I have a after market key-less entrie. I can get in the car but the car will not start with the alarm armed. I have tried to get new keys for the doors but they will not work and I rilly do not want to spend another $150 on a key that dous not work. Can anyone tell me another way to eather disarm or remove the alarm from the car? Sorry, It's a 91 Q45a. please help its been sitting in the parking lot for 4 days and I'm going nuts! O and there is not a Infiniti dealer within 200 miles from where I live. I have had the car for 2 years now and it's never armed before, strange?:confused: :help
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
Funny, at least with my 95Q, I think the alarm disarms just by unlocking the doors, with or without the keys. Are you sure it's the alarm? As far as key blanks and remotes, I've seen them on e-bay cheap. Instructions on programing the remote should be on a thread somewere on the forum. Do a search. But do take my word as law. I'm not one of the forum experts. Good luck.
Q45tech
Pull the thief warning [diasabling] relay out and make a spade lug jumper to close the circuit [start inhibitor relay feed] see wiring diagram in rear of FSM and pull the thief warning control module out.
It should crank and run if you think thru the circuit diagram process.
But depending on how the aftermarket was wired who knows?
modQ45
Car: cars
If I pull the thief warning relay out will the horn still go off ?Thanks, Q45tech I don't know what I would do with out you. O, yes I do, I would walk !
modQ45
Car: cars
If I pull the thief warning relay out will the horn still go off. Thanks, Q45tech I don't know what I would do with out you. O, yes I do I would walk!
Q45tech
The purpose was to crank it.
Pulling the alarm module module silences all the flashing and noise. There is an aux horn relay and a easily reach wire to the aux horn.
Members need to disscuss car thieft with a local expert, check your prisons on visiting days..........great sources of useful information. Surely they must have a union and web site?How to Slim Jim 101............is a useful skill.
modQ45
Car: cars
Q45tech can you tell me where the warning relay is? I do not have a wiring diagram for the car. it's been 9 days and I'm still stuck in the parking lot. thx
Q45tech
Relay #1 brown [where you jump to start] located where all the relays are underhood, closest one to fender and battery .........the inside of top cover has location labels.Relay # 2 lights/horn] is inside to right of fuse panel...row 3 top closest to steering column. You will have to dissassemble the left lower dash section.
Alarm ecu behind glove box.
Guess this is your punishment for failing to buy/have a FSM. Don't understand why you haven't towed to dealer.
I would not recommend doing the proceedure without studying the FSM and a knowlege of electronics, as you can screw up if you jump the wrong pins and burn up things ..................costing a real bundle.
Don't say I didn't warn you!!!!!!!!!!!!!!!!!
Aftermarket alarms without wiring and how they did it notes are a night mare we usually refuse to work on such cars or ask for a $300 minimum diagnosis fee.
modQ45
Car: cars
the alarm I need to disable is the factory alarm installed by Infiniti. The aftermarket one I had installed only controlles the door locks. The Infiniti dealer is in salt lake city which is 300 miles from Idaho. I have to do it or the car is never going to move again.
