Alarm question QX4
slpdave
Car: 1997 Infiniti QX4, 2000 Ford Explorer XLT
I have a 1997 QX4, I like the ride but yesterday I noticed the interior lights will not automatically shut off. I drove it around a good part of the day and actually forgot about them (sunny day). Well this morning I had to jump it off because of a dead battery. I drive to work, no issues. I do out on a break and hear chirp chirp chirp. I checked all the doors, all are shut, all the windows are up and everything was locked. I unlock with the key and get in. It will not start. it just chirps at me. I unlocked the doors with the key to reset that alarm but that didn't work. If I disconnect the battery will it reset the alarm?
And if it is something faulty, is there a way to bypass the alarm to get it home?
Thanks, David
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Disconnecting the battery will at least keep the battery from running down.If you leave it disconnected for a while, it will reset lots of stuff, including possibly the keyless remote programming (it did on a '95). So it's worth a shot.
I think you have to start it with the key to reset the alarm, not just open thedoor.
slpdave
I did disconnect the battery to keep it from running down, and also to keep the local wildlife from having seizures from the sound. ;-) The starter motor is disconnected by the alarm system so it won't start. But I did try to start it and it never shut the alarm off. I used the key, and the keyless fob, all to no avail. So I think it's a bad switch in one of the doors. Since I don't have a switch I had it towed to a trusted shop.
Chuck Tribolet
'87 Chevy Corvette
Ususally, the door switches are open with the doors closed, so unplugging it would have sufficed.
slpdave
Thanks for the info. I will definetely keep that in mind if this happens again. I can live without the alarm, I live in a relatively quiet/calm area. The only question I have is this, is the switch located inside the door or is it part of the latch assembly. I am not afraid to take the door panel off so knowing what area to look into would be helpful.
slpdave
OK, The QX4 has a Viper Anti Theft System which I did not know It had. It is malfunctioning causing the issues. I am having it removed from the vehicle.
Chuck thank you for your reply's I will keep the open/illumination switch in mind if I have simular problems again.
Chuck Tribolet
'87 Chevy Corvette
The switch is usually located in the door jamb, towards the rear of the door.Look for a little rubber bellows. That's the switch the sense whether the dooris open.
