SmoovC »
https://forums.nicoclub.com/smoovc-u179392.html
Fri Nov 01, 2013 7:28 am
I think your problem has something to do with the driver's door lock. The factory alarm is armed and disarmed through the driver's key cylinder as follows:
Arming is controlled by a brown wire at the driver's key cylinder through a single negative pulse, and also contols lock.
Disarming is controlled by a purple/red wire at the driver's key cylinder through a double negative pulse, and also controls unlock.
Disarming with no unlock is controlled by the intelligent key and ignition.
You did not indicate how you are unlocking the car; whether it be with the remote or the smart entry button, but I suspect that the driver's door key cylinder has something to do with the condition you indicate. It sounds to me as if the key cylinder is not sending the proper pulses to the alarm module.
