Alarm problem
WhiTTe Z
Car: '93 Z32 Twin Turbo 5spd
Whats up guys my name is Andy this is my first post just got my first Z a couple days ago its a 5 spd 93 TT and i'm pumped about it. It has 84k and since I got it, the alarm keeps randomly going off whenever the cars locked... I realize that there was inevitably going to be some electrical problems but this sucks. I cant drive the car anywhere because I cant lock it. What can I do? If i pull the alarm fuse will the car start? Does this indicate the wiring harness needs replacing?
WhiTTe Z
i would really appreciate any input at all
robomatic12
Car: 1990 300ZX TT
What alarm? Factory or aftermarket? Is the yellow "security " light blinking on your dash?
If you want to remove the factory alarm you just unplug the alarm module which is on the passenger floorboard above the ecu.
WhiTTe Z
Factory, and yes the light seems to be blinking always.
robomatic12
Car: 1990 300ZX TT
Either you figure out what door pin or hood pin is causing the alarm to go off, or you disable it. Could be the pin triggers or a problem with the alarm module itself.
WhiTTe Z
thanks,
Is the security light supposed to be on when the car is off?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
when you say the alarm goes off whenever the car is locked, do you mean that it goes off when you unlock it? uf so it's the door lock sensor on the inside of the door handle
WhiTTe Z
No i mean when the car is locked and sitting in the driveway the alarm goes off randomly like 2 times a day without anyone touching it.
evildky
06 Nissan 350Z GT
sounds like a door or hood pin issue, you coud always just pull the security fuse
WhiTTe Z
Thanks for your input, I just have it unlocked for now i feel bad for pissing off my neighbors. I need to experiment with it. Anyone know any good Z mechanics in upstate NY??
