SEinOttawa »
https://forums.nicoclub.com/seinottawa-u64350.html
Thu May 03, 2007 4:00 am
I have a 1997 Nissan Maxima SE, 5 speed. For the past 2 years, I've been having problems that my mechanic can't seem to resolve. Here it is:The problem started one day when I tried to unlock my doors with the key fob. Didn't work, so I used the key. When I opened the door, the alarm started to go off, and the car wouldn't start. The only way to stop it was to take out the horn fuse under the hood. After much fiddling around, removing/replacing fuses and relays, it finally started.Sometimes slamming the door out of frustration did the trick!Sometimes it wouldn't start at all so I just push-started it. This kept happening and I finally brought it to my mechanic. He checked everything and finally told me it was a missing fuse and charged me over $300 for the time it took him to find it!! I asked him if he could just disconnect the factory alarm, but he said it wasn't an easy task. A couple of days later...happened again. I finally decided to keep my doors always unlocked so I wouldn't have to take the chance of it happening again. It's been about 8-9 months now and the problem hasn't reoccured..until today! I manually locked all my doors, unlocked the driver door with the key..and the alarm went off. I removed the horn fuse to stop the beeping and now I can't restart the car. I've tried jiggling and removing/reseating both "alarm/clutch inhibit" relays under the hood, no luck. Please help! Another few things I should mention; 1- once in a while all the doors lock by themselves while I'm driving. 2- Sometimes (only SOMETIMES) the electric locks will work from the inside door switch. 3- The electric windows do the same, sometimes they'll work, sometimes not. (Usually NOT) 4- The key fob never works. Any help would be VERY useful!
Update: I got a used Body Control Module at a scrapyard. I was told that was my problem. Replaced it..still nothing!! I checked at the Nissan dealer that nothing needed reprogramming after the swap. And now I'm stuck with a used BCM, scrapyard won't give me a refund or credit
Does anybody know what it could be???
Thanks,Geoff
