franknitty69 »
https://forums.nicoclub.com/franknitty69-u25140.html
Wed Jan 03, 2007 5:27 pm
i've installed the 2WSS-AS in my 95 Q. It was hard as hell and this is my 4th time installing a compustar!
don't trust in best buy or circuit city they are idiots, but they do have surance. also they do not have the technical know-how to do this properly. even certifed compustar installers will have a hard time with the Q. It is a very technologically advanced vehicle. Waaay before its time. The LAN system is amazing!
and i used the 'omega' cd and the fsm for wiring. the omega cd was wrong for some of the colors but with the help of 'trial-and-error' and the fsm i was able to get it.
to get the full functionality of the compustar you will need quite a few inputs.
i can post my notes on saturday. but for now here's a few tips:
-tach - you can get this at the ecu-trunk release *either at the door switch (easiest) or at the trunk. AND USE A RELAY!!!-trunk trigger *body control unit (easiest) or at the trunk light-door locks - very tricky, must get it at the power door lock lan;-door trigger - use the little dome light under the steering wheel-hood trigger - use the factory hood pin switch or get it at body control unit-horn - there is a yellow connector for SRS at the right of the steering wheel, this is the easiest location to get the horn.-parking light - can be had at the connector under the dash *follow the steering column.-power, ignition, starter and accessory can be had at another connector under the dash *follow the steering column-95 q45 doesn't make use of the 2nd ignition, starter or accessory although there is one extra wire at the ignition and i can't figure out what its for.
i also did widow up, window down and motion sensor.
***WARNING*** IF YOU DON'T KNOW ANYTHING ABOUT ELECTRONICS DO NOT ATTEMPT TO INSTALL THIS ALARM YOURSELF!!!
