Alarm disable?
SR24DET
Car: RMS13
I have a 93 240sx se hatch and i got it in a junk yard. I put a new engine in it and i couldnt get the alarm to shut off. I talked with a guy and found out how to disable it. Sence then everytime i do something to my car my ****ing alarm goes off. Now i cant start my car, i think its my alarm that is stopping me. I looked at it and there are a million wires that the alarm is spliced into. any help on how to take out the alarm?
nisMo78
Car: 91 240sx
look under the dash and look for the brain of the alarm. all the wires and plugs go into it. there should be one long clear plug. probably with like 12 wires in it. unplug that one and it will kill the alarm.
HPR
Car: 1990 Nissan 240SX
^ That will probably be your best bet if you're not too familiar with alarm installs. From the sounds of it, your car probably has starter kill as well. If you can turn your car on, but it won't crank when you go to start, then you have starter kill.
IIRC, nissans have 2 starters wire leading to the ignition switch. I believe the main one is the black w/ white stripe and secondary one is black w/ yellow stripe. If you're black/white wire is cut in half, you'll have to reconnect those in order for your car to crank.
