95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Wed Jun 06, 2007 9:37 pm
i have no idea about the alarm system, but wouldnt it disable the keyless entry too if you are to remove the plug completely??, again, i have no idea, i hope that someone here can help
Second:- ECU says "EGR Malfunction" and voila!, the car won't start when hot (After driving) unless i let it sleep for an hour or so. Now it has become hard to start even in the mornings, after a good night of sleep.
I ordered a new EGR valve, and i know that the tubes need cleaning>My question:- Do i need to replace also the EGR temp sensor? the EGR Temp Sensor has it's own code, so if the code doesnt show up, then you wont need to replace it
- Can i reuse the gaskets on the EGR valve?the EGR gets really hot, so most likely the gaskets are toast, i would highly suggest replacing them along, it wont work properly otherwise (it will cause a vacuum leak), unless you have the metal gaskets, then it would be reusable (some VG's came with hard rubber gaskets), in that case, all you have to worry about is to tighten them correctly (corrcect torque)
- Is there something else i want to check? (as for the non-starting condition) I already replaced the starter (old one died horribly), Fuel filter and fuel pressure regulator, i had a "bad injector leaking" code, and the new fuel pressure regulator got rid of it (interesting, heh?).
very interesting..... check all your plugs in the back of the engine, make sure that they are all pluged in........ also ohm the injectors, they should be between 10-14 Ohms...... and most likely, the EGR should fix your problem
oh and to clean the EGR tubes, i think yodawill2000 had a write up about it about a year ago or so
