Thoughtful_One »
https://forums.nicoclub.com/thoughtful-one-u29843.html
Thu Aug 23, 2007 10:59 am
I know that the full aluminum bushings that have to be pressed into the subframe will cause the ride to become stiffer due to reduced slop from the old worn bushings, but if I recall, Hondas affixes their rear suspension pieces to the chassis, elimating any type of subframe.
If that's the case, the Al bushings would act like a solid connection, and any and all roughness would have to come from the differential (I'm talking about S13's with solid diff. mounts).
For those of you with severe harshness, have you checked/replaced the fluid in the diff., or checked for excessive play in the differential itself?
Did you re-torque the subframe nuts after driving on them for a while? Aluminum deforms easily, and if not re-torqued, there will obviously be play between the subframe and chassis and cause clunking and NVH.
The only reason I'm posting this is that I want to swap in a new subframe, and go the Al route, but everybody has had different experiences with them. I'm not going to pay a ridiculous price for Nismo pieces, or purchase collars. I have access to Al and lathes.
