Akebono Infiniti Brake upgrade (Help)
moneyteamlouis
Car: 2012 M37X Malbec Black
2015 Nissan Sentra Sr Black
Really need someone advise on here . I want to upgrade my brakes to the Akebono brakes but i don't think i'm ordering the right stuff, details are below. if someone could point me in the right direction i would really appreciate that. :dblthumb:
AKEBONO INFINITI Front and Rear 14" Big Brake Kit, 2011+ M37/M56/Q70 Big Brake Kit, 2011+ M37/M56/Q70
- Vehicle Application: M37/M56
- Brake Caliper Option: INFINITI - SILVER
- Rotor Options: Stoptech S/D Rotors ..
- Dust Shields: OE Sport Dust Shield..
- Brake Pad Options: Stoptech Performance..
- Brake Lines: Stoptech Stainless S..
- Brake Fluid: 2x Stoptech STR-600
$2,035.00 $2,035.00 :wtf2:
Ilya
moneyteamlouis wrote:Really need someone advise on here . I want to upgrade my brakes to the Akebono brakes but i don't think i'm ordering the right stuff, details are below. if someone could point me in the right direction i would really appreciate that. :dblthumb:
Seems like you're getting it from TunerzStore.com which is one of our sponsors (not to mention the owner is a moderator here). I'd say you're getting everything you need. If you have any questions, they have great customer service or you could just PM user "RED_DET" who is the person I mentioned in the last sentence.
And yes, going BBK isn't cheap.
DredM56
Car: 2011 Infiniti M56 2004 Subaru Wrx STi
Unless you track the car you're unlikely to be satisfied with the difference for that amount of money. Upgraded lines and pads would probably be plenty for street driving.
Debonair
I think 90-95% of the people that do this upgrade are doing it for cosmetic reasons, not performance or necessity.
DredM56
They do look cool but that's a lot of money to spend on that IMO. It doesn't look that cool not 2 grand cool.
Ilya
Debonair wrote:I think 90-95% of the people that do this upgrade are doing it for cosmetic reasons, not performance or necessity.
Yep, this is the only reason I'd really do it and why I haven't...as Dred said, I can't justify $2k for a largely cosmetic mod. I'm a good enough driver that I leave myself distance, etc. 99% of the time (I ride a motorcycle so I'm SUPER aware of my surroundings, space, etc.).
Only way I'd do this is if I could get everything from a donor car for $500 or so.
Larz
Car: 2019 Q70-L RWD
I agree. Those calipers look brilliant. Maybe I'm too frugal to spend that much on something that makes very little difference in safety or performance. My Brakemotive rotors and pads have save me many times while braking in huge puddles from a good speed. I doubt akebono would have done $2,500 better. Instead, I added MGP caliper covers to my standard brakes and they stand out much better, 'look' much sportier and get noticed very often. They also keep the brakes cooler and dramatically reduce brake dust on my wheels because the dust is expelled under the car and onto the roadway.
MGP - black gloss powder coat - no etching, no branding + Infiniti caliper decals from Ebay
6061-T6 aerospace grade aluminum and TIG welded
Debonair
Calipers and OE replacement rotors are all that is required for this mod, right? Everything else is optional and/or an upgrade. So with used calipers and new OE equivalent rotors this should be doable @ $1300'ish.
moneyteamlouis
reason why i want to the upgrade is due to when i'm doing high speeds my car steering starts to vibrate, so i was think if i upgrade my brakes just what i did with my Lexus it would stop. so if someone has a better plan i'm open for it
ArmedAviator
Car: 2012 Infiniti M37x
Larz wrote:I agree. Those calipers look brilliant. Maybe I'm too frugal to spend that much on something that makes very little difference in safety or performance. My Brakemotive rotors and pads have save me many times while braking in huge puddles from a good speed. I doubt akebono would have done $2,500 better. Instead, I added MGP caliper covers to my standard brakes and they stand out much better, 'look' much sportier and get noticed very often. They also keep the brakes cooler and dramatically reduce brake dust on my wheels because the dust is expelled under the car and onto the roadway.
I'm very intrigued by this as the one rear brake caliper that I had replaced with a Centric part is rusting and unsightly. Easy install? How are they mounted?
moneyteamlouis
i haven't done anything to my brakes as of yet, its something i notice when i'm driving
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Having just upgraded my stock brakes (non sport) to the Akebono kit from TunerzStore a couple weeks ago...I can say they made a very noticeable difference in stopping power and pedal feel. I opted for slotted rotors and Project Mu pads. The dust shields in the rear must be cut to fit the bigger rotors and the front must be bent back in one spot to fit. If you opt to buy/replace the dust shields it's going to be a lot more time and labor to get the old one's off and the new ones on. I would advise tin snips to cut the old ones.
While the upgrade does look nice I did this for the performance; but I also drive it hard. When I was on Tail of the Dragon 2 years ago I had brake fade and had to back off the entry speed. It wasn't that I pushing 10/10 it was just constant hard braking and the stock brakes couldn't take the prolonged use. IMHO all M37/56 Q should have sport size brakes based on the size and power of the car.
While it is pretty expensive; make no mistake this IS a performance upgrade.
Ilya
wideopn11 wrote:Having just upgraded my stock brakes (non sport) to the Akebono kit from TunerzStore a couple weeks ago...I can say they made a very noticeable difference in stopping power and pedal feel. I opted for slotted rotors and Project Mu pads. The dust shields in the rear must be cut to fit the bigger rotors and the front must be bent back in one spot to fit. If you opt to buy/replace the dust shields it's going to be a lot more time and labor to get the old one's off and the new ones on. I would advise tin snips to cut the old ones.
Ahh, nice to hear that review. Thanks!
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
ArmedAviator wrote: I'm very intrigued by this as the one rear brake caliper that I had replaced with a Centric part is rusting and unsightly. Easy install? How are they mounted?
Same here. Bought a caliper from Rock Auto and it looks like it's 200 years old now. If you click the link you'll see what it looks like now. If you scroll you'll see what it looked like brand new. https://www.flickr.com/photos/22693517@ ... res/85oq1u It's clicking like crazy now so I'm going to rebuild the old one (glad I didn't send it back for credit yet) and send them back their BS caliper.
Also, I was looking at brake pads last week and I noticed there is a different brake booster for the sport vs. non-sport models. Any one else come across this and would it make that much more of a difference?
Reason: Fixed quote
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
I have had no one purchase the OE dustshields.... the cost to include labor vs the minimal time to modify the existing dust shields is a no brainer.
We normally have another rotor alternative, Stoptech standard rotors which are included in price, but they are out of stock @ stoptech for the rears.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
This is what my rear dust shields look like after the trim. You have to trim the whole lip around circumference and you have to trim out the area on top to expose more of the caliper mount to accommodate the bigger size.
moneyteamlouis
Thanks alot i'm still doing research on it and i'm going to be buy brake system individually
RED_DET
Vendor
2011 Infiniti G37x
Stoptech Standard Rotors now available... $1641 plus shipping for the kit you outlined w/o dust shields.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
So I just found out that the stock/non-sport spare tire that I have will not fit over the new BBK. FYI. Guess I need to track down a spare tire for the sport model assuming its different. :facepalm:
RED_DET
Vendor
2011 Infiniti G37x
Sport model has different spare... same issue the G guys run into as well.
