Altima coupe Akebono brake upgrade
All things Altima Coupe.
ProjectZ35023
Car: 2011 Nissan Altima Coupe SR 3.5 2dr
Yes the fit use the 370 big brake kit buy brake lines on Z1 make sure you get the (q50 lines) 370 Lines too long for the front and run 20mm spacers with oem wheels result may vary if your running aftermarket wheels
That looks great! Which pads did you wind up using?
