i240sx »
https://forums.nicoclub.com/i240sx-u66847.html
Wed May 27, 2009 6:30 pm
today was my day off work and school was over, i decide to remove my AIV piping(connect to the header) to see if it what affect the idle.
motor
AIV box
spray the bolts with d40 to make things easier
unbolt this bolt make things easier
bolt out
from under
after i unbolt it i turn the engine on, let it idle for 5 mins. the idle was where it was suppose to be. nothing change except for the horrible loud ricey sound.
it was getting dark so i bolt everything back up.then got online and found out you can use a .25 quarter to block the hole and screw it back in with the same bolt.
EDIT: its not a quarter, its a nickel (wrong info on the net about the .25)
MORE TO COME... WILL SEE IF I PASS SMOG WITHOUT THE AIV....WILL REMOVE IT AND SMOG IT SOMETIME NEXT WEEK...
Modified by i240sx at 3:51 PM 5/28/2009
