Aiv????
FTRS14.5
Hi,I did a search on this and came up with nothing so here is my question, does anyone have a picture of what the AIV assembly looks like? I removed the part from the turbo outlet and plugged it with 2 nickels and some JB weld (Thanks Budd), but I am unsure of else I am suppose to remove. I noticed that there is a pipe the runs into the head. Would that be it?? I will take some pics of what I am talking about and post them up tonight. Any advice would help, thanks in advance!!!!
TruboostPerformance
The AIV setup is connected to your EGR as well, it is located right on the side of the valve cover cant miss it,driver side that is, also you can remove your canister or leave it on which is in front of the driver side tire. just make sure you plug off the two lines comming out of the EGR unit and go to your throttle body, one is the size of a vaccum line and the other a little bigger, good luck.
FTRS14.5
Thanks for the info!!!!
