rsmithdrift wrote:trust me that black box does nothing and it makes no difference if the aiv has a breather or goes to the intake, it all runs the same. It'll only improve your performance if the aiv was leaking.
The black box may not do much, but running a breather to it is not a good idea. Here's why:
If your aiv solenoid failed, which is why a lot of ppl remove the entire assembly, it will allow exhaust gas to go back out that hose -> goes in to your engine bay - not as bad as having the hose directly connected, but I don't like having exhaust gases dumping in my engine bay either.
The other hoses near the throttle body are for idle and crank case ventilation etc. You "need" most of them.
Just get an injen intake or something - that has all the connections you need.
