Woodnutz78 »
https://forums.nicoclub.com/woodnutz78-u283931.html
Tue Mar 19, 2019 5:13 am
I had the gurgling, and just removed the system altogether. I figured if I'm going through the trouble of getting to it, I might as well take it out completely. I did this along with a couple other deletes and my timing belt change... yet to finish that. Any decrease in vacuum plumbing is a decrease in potential leaks. That being said, if you're opting to leave the system in, I don't believe there's any downside to just leaving the open hole. I believe there's testimony of plenty of people doing this with no notable effect.
Of course, if you have concern about it, you can just disconnect the hose, dump the water out, and reconnect it. You'll just need to be prepared do it again at some point.
