Dragon: You dont spray the engine with water hehe. Sorry i wasnt specific, i was just going through the diagnostics quickly when writing.
Using a can of WD40 on the top end of the engine can expose leaks that you may have when the engine is running, leaking air will cause the fluid to bubble thus showing if you have a leak.
SOme of the possibilities were Injectors (seats and nozzles) as well as head gasket and so forth. Spraying them would reveal if there were any leaks.
Chingon: Being a mechanic for a number of years generally prevents me from taking the car in for a diagnostic until im totally sure that there is nothing mechanical oppose to electrical that could be the problem
That way i minimize the hours they spend on the car when i take it to the shop, because i have checked everything other than plugging in the coder
As i mentioned, it seems to be eletrical. Could be the MAF or TPS, thats my last resort now i think. Ill post when i find the problem.
