AIV hoses
lord_hypnos
I'm not sure where to find all the hoses to plug. I have two of them. One of the small vacuum hoses and the big one. Maybe if you could explain a little more in detail or show me a picture of where they are located.
Also what did you use to plug them with? I just used some screws but I think I wanna go get some hose plugs. Hardware stores?
Thanks...
Crunkrich
Car: 1992 Nissan 240SX (R.I.P.)
2000 Cherokee Sport 4x4
dude its matt from csr... I think those hoses come off the airbox... check this http://www.240sx.org/faq/index.html
[threadjack]
is our cruise still on? I'm having a ***** of a problem with my lsd swap I dunno if I'll be able to bring my 240 out there.
[/thread jack]
lord_hypnos
thenameismatt wrote:dude its matt from csr... I think those hoses come off the airbox... check this http://www.240sx.org/faq/index.html
[threadjack]
[/thread jack]
Yeah it's still on! Should be pretty decent amount of people. Other Nissans are comin as well. EX. NX, 300zxs uhh yeah.
vancouverbc
Car: 1991 240sx
If your only goal is to stop the ill effects of the AIV, you only have to disconnect the hose at the air filter. This prevents water and exhaust from contaminating your maf and throttle. etc.. If you want to remove the whole thing to create more space, then you have to obviously remove all the hoses. Pretty self-evident. I used rubber knobs for the larger hoses and exhaust pipe and goop for the two vacuum lines.
vancouverbc
Car: 1991 240sx
zerothread?id=124117
Here is thread on aiv with pics. I was pretty ignorant at beginning but i think I mastered things by end of thread.
