1) Block the open pipe from the stock side mount intercooler recirculator outlet.
2) Install any BOV that fits on your hot pipe flange.
3) IF you recirculate the BOV (nice but not critical usually) the outlet from the BOV needs to be piped to the inlet port on the rubber intake tube that goes between the MAFS and the turbo compressor inlet.
4) If you do not recirculate the BOV, block the recirculator inlet on the rubber MAFS to turbo tube.
5) If you do not have the rubber MAFS to turbo inlet tube, you can buy one or make one. If you make one, it will need the recirculation inlet ONLY if you are recirculating.
EDIT: thanks to whomever this pic belongs to...
The recirc inlet is the larger port at the opposite end of the filter, with the worm gear hose clamp showing.
