aircooled vs. intercooled
Frankenstien93
Car: Nissan 240sx SE
can you run a t3/t4 turbo without an intercooler if you drive it normal or will it be too much heat for it and ruin it?
WDRacing
Depends on how much boost you want to run. Keep it down to 5 psi and you should be ok. I'd retard your base timing a few degree's juts for safety though. What are you doing for fuel control? If you use a 12/1 FMU you'll run rich enough to not need a IC.
WD
sunnys14
Car: S14
5psi max! anything more and detonation will occur because of too much hot air.
Frankenstien93
yea ok im going to run 8psi so and ic would be a must so i should retard the timing a little bit how would i do that or would i need to buy a special part or can i just turn the rotor back on the distributor?
HolyShiznit
Car: Working on my car
It should be noted that retarding the timing increases the amount of heat within the engine, so I don't even know if 5 psi would be ok. If you have the money for a T3/t4 then you should be able to afford an intercooler. Be safe...
sunnys14
Car: S14
a cheap front mount intercooler setup shouldnt be more than 350 bucks. you can always get a SMIC off an SR for even cheaper too.
WDRacing
A few degree's base timing isn't going to heat up the EGT's that much. Plus by retarding the timing your reducing the cylinder pressure anyway.
What are you using for fuel management? If you keep it rich with a FMIC, you can simply retard the base timing like 2 degree's and be very safe.
WD
