For those with air suspension, post psi and pics of your when its airred to the pressure that you regularly drive at. I'm not looking to see how low it is parked, I want to see how low (or high) you guys on air are driving. I'm fairly new to air suspension and still trying to figure out what psi I should run on my Y33. Haven't driven it long enough to find my comfort level. I'd like to park it on the ground and still drive low but not blow my shocks. Also, post your air suspension set up so I may serve as a good reference.
I'll start. 1998 Infiniti Q45 on coilovers with airbags. 90 psi in the front and 60 in the year. Might run less psi in the front or just lower it another inch from the coilover but I'll have less max lift if I do that.
Driving height
Front
Rear
Max lift
Max lift - front
