Airbag sensor blinking after A/C Condenser cleaning
TellarHK
Car: 1994 Infiniti Q45
1995 Jeep Wrangler
1990 Nissan 300ZX
My roommate and I just went through and followed the directions posted here on how to clean the A/C condenser, and unfortunately now seem to have a problem with the air bag light blinking steadily. I've gone and used the 10-push reset with the car in "on", but that doesn't appear to have done the trick.
Does anyone have suggestions?
EDIT: Crisis averted. Either the valet key wasn't enough to trigger the system reset, or it needed 20-odd triggers of the door switch to clear it. We just ran through the process a few more times and it finally cleared.
And the A/C's just a bit cooler now.
Modified by TellarHK at 7:39 PM 5/18/2009
goody90q45
Car: 1992 Infiniti Q45 (sold)
Did you unplug the yellow airbag connector below the glovebox when you took it all apart?
TellarHK
1995 Jeep Wrangler
1990 Nissan 300ZX
goody94q45 wrote:Did you unplug the yellow airbag connector below the glovebox when you took it all apart?
Yeah. I was doing some reading of the manual and some of the forum posts here after I put up my post, and that looks like exactly what happened.
