RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Tue Jun 10, 2008 8:23 pm
Steps to follow:
Turn ignition on, but don't start the car.The air bag light will be illuminated and after seven seconds it will go out and then start blinking.As soon as the airbag light goes off, immediately turn the key off and count to (5).Then do the same steps above (2) more times.After turning the ignition off on the 3rd time around for (5) secs, turn the ignition back on again. The airbag light should illuminate and after (7) secs again it will turn off. At this point it should stay turned off and not flash, if it does report back. If it does stay off, start the car and make sure it isn't flashing.
