Airbag light flashing...
g35sedanlover
Car: 03 Infiniti G35 Sedan
I just changed my cabin air filter yesterday and today I noticed a flashing light on my dash for the air bag. When I removed the glove box, I did unplug a few wires but none of them seemed to be related to the airbag. When I reassembled I double checked everything and it all looked good. Is their a reset I can try or something?
joe603
Car: 2014 Durango R/T
You can try to reset the ECU....hopefully you don't have to take it to the dealer. You did plug everything back together, right?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
ECU reset won't work, its a bit more elaborate. You have to put the car in diagnostics mode to get the light off.
zerothread?id=310699
g35sedanlover
I have the service manual and I still couldn't seem to find the reset procedure... Worked perfect!!! Thanks for the help
PSNICO > Sliced bread
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
What did you do to fix the problem? ECU reset or diag mode?
g35sedanlover
I followed the link that RED_DET posted and did that. It was a combination of turning the ignition on and off.
Andy_V35Sky_350GT
Ah ok, I have tried that a dozen times and it just does not work on my car. Oh wells.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
When i did the proceedure, I actually did what it says like 5 times instead of 3.....
that was the only way it worked for me
took me several attempts to get it right, but once i did the light stayed off
g35sedanlover
Took my seats out to install fatmat and now the airbag light is back on. When I tried to click on the link from red_det it didn't take me anywhere. Can someone help again?
tollboothwilley
HERE YOU GO
use the search button next time
http://forums.g35club.org/zerothread?id=351969
tollboothwilley
I installed Fatmat too.
How do you like it so far?
g35sedanlover
better, not quite what i was hoping. That said, I still have more to do. I did behind the rear seats, and the entire floor. I still need to do the trunk, doors and am thinking about the front fender wells under the hood. Where did you stick it?
g35sedanlover
Has your car stopped smelling yet?
tollboothwilley
I haven't finished all of what I want to do. i did the trunk first. That was a lot of work because of my subs and stuff. I covered the entire thing. I think it cut down exhaust drone quit a bit.
Car still smells a little like tar. But the smell has subsided quite a bit.
Not sure if i would have gone with Fatmat if I were to do it again. Probably would have gone with B-quiets butyl mat.
g35sedanlover
Yeah, I think second skin has a good buytl mat also. If I knew fatmat would stink so bad, I never would have used it... I also just bought a gallon of second skin spectrum and a spray gun. I want to do the fender wells and trunk with it.
