My name is Alex, and I recently acquired a 1991 N/A 2+0 300ZX. The car is great, but unfortunately, I've already encountered a few problems with it. I was told by the previous owner that there was something wrong with the battery, but when I tested it, it was fine. Now, here's my dilmmea: Normally when you turn the ignition to the ON position, all the lights on the dash come on, and then some of them turn off after a few seconds, right? Well, the CEL doesn't turn off, but when I start the car it does, so that's a relief. The airbag light, however, doesn't turn off and stays on even while the car is running. Another problem I have is that the radio, which is an aftermarket radio, has no power. Also, I don't know if it's just a Z thing, but the car seems to crank over kind of on the slow side, but I've never had the car not start.
So to summarize:
Airbag light stays on even when the car is running.
No power to the radio.
The CEL doesn't turn off like it's supposed to after a few seconds but does when I start the car.
The car cranks over kind of slowly but has never failed to start.
What do you guys think? Any help would be greatly appreciated.
Thanks,
-Alex-
