Airbag light came on a month ago and keeps flashing!!!!!!
Romo77
About a month ago my airbag light just came on by itself and ever since just keeps flashing. Should I try removing battery heads and see if it resets itself or does the module need to replaced.
I haven't had any accidents or anything like that to triger it.
thanks
yodawill2000
Car: 94 Infiniti J30
My J30 did that ..Someone here gave me the fix ..
Open the door .. turn on the ignition (Not Starter) and tap the door switch 5 times VERY quickly The door switch is down at the bottom ..
Romo77
R U talking about the little part that when you close or open the doors slides in or out ????
CJQ45
Car: 1997 Q 77k 03 Maxima GLE 19k
The stwich is the open door trigger on the drivers door towrds the bottom. Turn the inginition on - dont start the car - just all the way on and rapidly press and release the button 5 times. Turn the car off and turn on after about 30 seconds - you should be good to go.
If this doesn't do it - you GOT some problems - either the airbag module (harness) went bad or the car was in an accident.
Romo77
I haven't had a chance to respond and thank. WOW that was easier than I thought. I followed the directions and within seconds the problem is resolved.
THANKS...................
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The problem is the airbag computer is put into diagnostic mode. Its odd how that happens, it did it to me after I had the battery undone for a few weeks (often i unplug my battery when i go on long trips so i dont have surprises!!!)
