kmiles »
https://forums.nicoclub.com/kmiles-u181661.html
Tue Mar 22, 2016 2:19 pm
I had a similar problem on another car and did a lot of research at that time. The blinking light indicates that the system is impaired and there can be multiple reasons for it. In my case, I found a connector the had become disconnected behind the glove box. I would recommend that you be careful as you troubleshoot - as you could accidentally trigger an airbag release while troubleshooting. Here is caution note:
TROUBLE DIAGNOSIS
Trouble Diagnosis Introduction
CAUTION:
Do not use electrical test equipment on any circuit related to the SRS unless instructed in this Service Manual. SRS wiring harnesses can be identified by yellow and/or orange harnesses or harness connectors.
Do not repair, splice or modify the SRS wiring harness. If the harness is damaged, replace it with a new one.
Keep ground portion clean.
