Airbag light blinking?
SHIFT_THIS
Car: '02 Frontier XE
Ok so i got a '02 frontier and the airbag light is blinking. My Nissan factory told me to unplug the battery for about 30sec's to a min or so. the it will stop doing it. well after i did that **** it still blinks. anybody got the same prob and other that taking out the buld how can i stop it??
soccerbrace
Car: 04x
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
gullymonster
Car: 91 d21
What can you do if step 4 doesnt take you to diagnostic mode
Q451990
The Have you checked the service manual for the diagnostic procedure, it might be different for a '91? It looks like we're missing the 1991 manual, but I'd think the 1990 would work.
http://www.nissanservicemanual.com
