Airbag light...again 2008 Rogue
ghuoof
Car: 2008 Nissan Rogue S
I tried searching around for more info and got conflicting results. My Rogue's airbag light is blinking. I tried doing the reset trick a few times and it didn't work. Should I replace the spiral cable? Everything else on the steering wheel seems to work, which I read means it's probably not the cable. But it sound easy enough to replace. What else could it be?
Thanks in advance and sorry if this has been posted a thousand times before.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There are a zillion things which can cause SRS codes on a 14 year old car. It's easiest to find a parts store with an SRS-capable scanner, but it is possible to get blinky codes on an '08. See SRC-158 here:
https://www.nicoclub.com/service-manual ... %2FSRC.pdf
Return to “Rogue Forum”
