airbag indicator light
Nissan 350z / Nissan 370z general community discussion forum
twoeazy
My air bag indicator light 05 350Z Touring Roadster just came on and flashes.Any easy fix for this problem?
samej82
Car: 2007 Nissan 350z
flashing usually indicates a malfunction... check your dealer... u could reset...but u might want airbags..
z350z
Car: 350z
if your gonna buy new airbags than ill buy those off of you?
simplewon
Car: 2004 black roadster
loose connection on a sensor. Gets to be to much of a problem, let the dealer fix it so you don't set off an air bag. For now, reset the computer, mine goes off about once per mo. Air Bag Reset Reset ProedureThis procedure has worked for some people. Others claim it does not work, however it was pulled directly from the official Nissan Service Manual. So if it does not work for you, then there may be a problem with your airbag system and it should be checked out. 1. Turn ignition switch from OFF to ON. 2. Air Bag warning lamp is on for 7 seconds and turns off, the turn ignition switch OFF within 1 second after the lamp turn off. 3. After ignition switch is turned OFF, wait for more than 3 seconds. 4. Repeat steps 1 to 3 two more times. (Perform 3 times in total.) 5. Turn Ignition switch ON. 6. The SRS lamp has been reset it.
Return to “350z / 370z Discussion”
