airbag flashing
NY_Pito_NY
Need help locating the airbag sensor...i know for fact that it has never been deployed...what should i do?:help
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If the airbag light is flashing, it may just be in diagnostic mode, and in actuality you may not have anything wrong...... i had a similar problem on my car........ Im not sure about the Js, but on the Qs, all you have to do to switch modes is turn the ignition switch to ON, and then press the door switch 5 times within 10 seconds of turing on the ignition.......
The drivers side door switch is <while looking at the door FRAME> is the little black thing on the bottom right, with a little black nubbin covered by a rubber boot..........
PalmerWMD
Car: 2004 350Z
De[ends on which sensor.The impact sensors are in or under + behind the bumber.Square black boxy things left and right with yellow sticker on them.
Fred...:)
QuickSilver
My airbag light is flashing and I've tried Wes' solution with no results. Does anybody have any other solutions?
NY_Pito_NY
ok Thank you wess i will let you know what happens...
NY_Pito_NY
elwesso wrote:If the airbag light is flashing, it may just be in diagnostic mode, and in actuality you may not have anything wrong...... i had a similar problem on my car........ Im not sure about the Js, but on the Qs, all you have to do to switch modes is turn the ignition switch to ON, and then press the door switch 5 times within 10 seconds of turing on the ignition.......
Elwesso you the man...it worked as far as i can tell..you dont know how long i had that stupid thing flashing 3 years...Thanks
elwesso
2007 BMW M Coupe
Dont worry dude, I posted a thread on it too...... It is weird, it will randomly go into diag mode, and even if you let it sit overnight with the battery disconnected, it wont stop...... It has come up on me 2 times in the 4months ive had my Q!!
Always glad to help :)
elwesso
2007 BMW M Coupe
QuickSilver wrote:My airbag light is flashing and I've tried Wes' solution with no results. Does anybody have any other solutions?
Well that means that it is flashing because of a problem...... Without having a service manual, it would be next to impossible to figure out over the board..... If you need a manual, email me off board!
If it is solid (not flashing, but on), it is the fuse......
