Airbag blinking and rear lights not working after stereo install
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
mesamale22
Car: 2006 Nissan Altima
I put a new stereo deck in my car and after everything was hooked back up and working
my rear lights stopped working, some of my interior lights stopped working, and my airbag light is blinking all the time
any help would be apreciated.....this is really starting to anoy me.
I put everything back in place to to troubleshoot my steps and after i put everything back to normal i am still having the same issue
froggysquasher
Car: 2006 altima s 2.5
check your fuses . mine did that in my accord and i had blown my interior light fuse under the hood wheni hooked up my stereo. had a remote wire hit a ground wire and that did it. and check the fuse box inside the car 2. prob a 20 amp fuse
saywat
did u unplug the harness in the climate control? i remember reading that the airbag light would start blinking as a result and it needs to be reset somehow. might have to go dealership
JunseiMotors
Car: 2010 Nissan Titan LE
2004 Acura RSX Type S - Supercharged
1986 Toyota AE86 GTS (hatch)
As for your taillights not working, im sure that has something else to do with it but I can help you with your airbag light. Just have your local dealership or someone with a scan tool which has AIRBAG control reset the light. You disconnected the harness plug from the back of the climate control. Thats all that is. We have to reset them all the time for several audio install shops here.
Return to “3rd Generation Altima Sedan (2002-2006)”
