DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Feb 19, 2004 9:35 pm
My guess: Probably needs a resistor. I would think the resistance of the sensor would never be 0 or infinity, and a wire or unhooked will give these values, which the ECU is probably programmed to flag codes for. You need to know the resistance of the sensor at the temp you're running in. But the car won't run quite as well as it would with the sensor in place, except at the temp you select the resistor for. It'll run leaner when cold and richer when warm.
