deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Apr 30, 2006 9:16 am
Yeah man, I remember, No more sohc NA huh? You building a turbo set now? Ive been great, and even better now that spring/summer is here once again! Finally get some heat down onto that asphalt
That ecu you have (G40) is an early 9.1:1CR version and it does not need the IAT, obviously since you are getting the code 55. So if this is in an original car/engine, it should be the 9.1:1 compression ratio.
If you were to swap a later model 90 ecu on that car you should pick up some power, but you would have to wire in an IAT (1 wire, ground is shared with others.)
You been over to check out eccs.hybridka.com ecu tuning forum yet? Lots of info for ka24e sohc ecus as well as the dohc.
