niznos »
https://forums.nicoclub.com/niznos-u14767.html
Tue Mar 23, 2004 5:06 pm
I would try to find a replacement for it, new or used, it doesn't matter as long as it works. Here's what it does, as far as I understand: The ECU sends voltage to the sensor and looks for resistance. When hot, the sensor puts out almost no resistance, when frozen in a freezer (someone tested it according to another thread), it's around 10k ohms. The ECU sees the resistance, along with other input from other sensors, and adjusts mixture, spark advance, etc.
When you get your new sensor, it's better if it's attached to the intake where it can test for actual air temp., but if that's not possible, at least attach it near the air filter so that it will get a better idea of what's going on.
Do not splice the wires together as it will see no resistance and you will run lean all the time, and may trigger a trouble (check engine) light. Unplugging it will likely do it too.
