Air suspension
thm8d
Car: 07 Infiniti M35 Sport w/ Tech pkg
I'm curious what everyones running. I'm thinking about getting a Air Lift kit but for a g35
mexillis
Car: M45s
So you're looking for bags to mount on a G35 on a M forum or buy G35 bags to mount on a M? Most people have used UAS bags over oem struts. Then upgrade to a set of coilovers on UAS bags. I have seen a few problems with airlift but on G37's. I am on D2 bags and I know of some others with K sport. Accuair for all the valves and control is the best way to go IMO for management.
Ilya
How much does this cost? How hard is it to do? After the BBQ meet, I toyed with the idea of 'going big or goin home' for suspension. Is the ride more comfortable?
thm8d
Well I have w huge discount on air lift. I'm planning on getting the g35 kit to mount on my m. The kit is pretty much plug and play. Everything is labeled and has full instructions. If you know how to install a radio and coilovers, you'll be able to install the kit. As for ride, I can't comment on air lift but my friends have uas bags over stocks and its too bouncy. My other friend has uas over BC and accuair management and it rides smooth. I'm just curious to see if there's any cons to air lift before I pull the trigger
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
How is aftermarket air suspension in winter...especially the brutal winters of NY of late with the salt? I've seen way too many Ranges and Expaditions riding on their tires in NY.
thm8d
I live in Cali so I don't have to worry about winter haha. If you live anywhere with freezing conditions, you have to worry about water freezing up in the lines. Once your car warms up the lines, it'll melt it and work fine
mexillis
Car: M45s
idk too much about airlift's quality besides from what I mentioned on the G37. For cold weather as long as you have water traps you should be good and not have to worry about freezing lines. No problems with my car so far in freezing temps. You could also add the brake line non freeze additive to the tank if you want to be extra cautious. RM450GT lives in NY and I dont think he has had any issues with the lines freezing. For cost on bags it could run either 2500 for a baisc kit up to 4000 plus depending on what you add. If you have CO's already it would be a lot cheaper since you just have to remove the springs and add the management.
thm8d
Alright everyone, I'm picking up a airlift kit. I'll probably install it tonight. Stand by for updates
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
thm8d wrote:Alright everyone, I'm picking up a airlift kit. I'll probably install it tonight. Stand by for updates
This should be very interesting
thm8d
I installed installed my air kit. Sorry I didn't take pictures of installation. I don't have much time off work so I didn't want to waste any time. Now my question to you guys with air, how do you get the front to lay frame? I Can only get about 1 inch off the ground. Pics will be up tomorrow
thm8d
stm37s
'11 Infiniti M37 S
thm8d wrote:Image
Very nice
svard75
Car: 06 M35x
Jack the car up, take off one wheel and put a jack stand under the lower control arm then lower the car and see why. I'll bet it's either the upper control ball joint or you front sway bar.
Ilya
That looks nice...makes me wanna get one.
Deedub
Car: 2006 M35 sport
Car looks great! I wanna do air suspension... Where did you purchase your kit from and what did it run you?
mexillis
Car: M45s
To get this low
you will need all the stuff from T-Demand.
