air regulator question.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Question for you guys. I know the theory of operation of the air regultor. If i went in and manually closed off the valve permanently do you guys think it would hurt the idle at all. This is of course if the car is warmed up to normal operating temp and the air reg closed. what do ya think?
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
thats an interesting question...im thinking it might make ya run slightly rich..throwin a bunch of codes at yadue to the changin O2 and Fuel lvl's at a standard RPM...im of course not shure about that..but that is what is crossing my mind ..if im thinking of the same part as your are..the idle air controll valve..interesting question thou.
USMCgetsome
i'm talking about the iacv air regulator. Its the other valve with the bimetalic stip that closes at temp.
seang
Car: Ford Fiesta ST
Do you mean the thermostatic warm air intake? If thats what you mean, then you can defeat it, if your climate is kind of warm. If it malfunctions on its own, the car will run like its out of tune because of the hot air.
vancouverbc
Car: 1991 240sx
i
KUILLIN_DRIFTER wrote:Question for you guys. I know the theory of operation of the air regultor. If i went in and manually closed off the valve permanently do you guys think it would hurt the idle at all. This is of course if the car is warmed up to normal operating temp and the air reg closed. what do ya think?
nt
i dont see how. there is a bit in the tutorials under air regulator
