dattodude »
https://forums.nicoclub.com/dattodude-u30125.html
Fri Aug 18, 2006 1:32 pm
Cold idle is bumped up with the regulator under the throttle body. It slowly closes over a period of 10 minutes. It is not adjustable and closes using a bimetal strip that has 12v from the injector power supply connected to it.
Base Idle is set by the fixed adjustor on the block on the side of the plenum. IT can only be set while the AAC valve is disconnected.
Airconditioner Idle increase is set by allowing a fixed amount of air past the TB, using the blue connector (FICD) on the idle block on the plenum. Without A/C connecting this is pointless.
The AAC valve is a pulse width modulated valve, that opens and closes to raise the idle when the engine is about to stall, or if the base idle is set too low.
The problem with CA18s is that this idle control block gets chocked with carbon rubbish, so the base idle drops as a result of this restriction, and everything else starts going 'poltergeist' after that.
The AAC valve has to work 'all of the time' to keep the engine from stalling because the base idle (mechanical adjustment) isn't providing enough air bypass to maintain an idle of 850rpm.
People talk about CA18s with a bad idle, where it jumps up and down. This the AAC valve trying to do the job of the base idle adjuster.
The engine also can set idle higher through the AAC for when it is cold. If the engine temperature sensor is faulty, this can also result in strange idle problems.
So there..
- Clean the AAC/FICD valve block as a first measure. Be careful not to break the gaskets when you remove it to clean it.- Clean or replace the Cold idle solenoid. They can get choked up with oil/carbin rubbish too. Although it is less common.- After that, when the engine is warm, while the engine is running, remove the AAC valve connector. And set the 'base idle' to 850rpm using the 10mm bolt/screw on the rear side of the idle control block. Reconnect the AAC connector. This is your idle set using the proper method.
Cheers,Chris
