Air Regulator install help!
Tsukai240
Ok i just got a used air regulator for my 91s13. i heed a lil guidance on the install. Since the dang thing is inbetween the uper and lower runners of the intake manifold, i wanted to remove the bolts holding the 2 halves together spread it appart and swap it out with the extra room. then i noticed there is a bracket that supports the manifold to the block. i can't remove it. hand tools wont work. the only other option is to go in through the front but that may not leave enough room for hand tools. what do i doo?
BTW the used air regulator is from an s14 and its reading 61ohms resistance. the fsm says its supposed to be 75. is it still good?
Tsukai240
can anybody help me? nistech???
s13sr20chris
61 should be ok. i will tell you right now that you need to remove the entire intake. maybe somebody knows a trick that i dont know but i think you have to remove the whole darn thing. i have done it. its not that bad.
