float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Jan 22, 2008 8:42 pm
They're not all the same. Most don't have 2 hose connections. Most feed the air directly into the manifold via the side of the unit. The CA uses and inlet and outlet hose.
It's normally in the open state. So when it's cold, air should pass through it easily. The colder it is, the more air should pass through it. If you connect 12V to it (it's not polarity sensitive) after 5 min or so there should be little to no air flow through it.
