Yup, agreed, it's a safety thing...prevents your windows from getting fogged up. The AC condenser removes that moisture and puts it OUTSIDE of your EX. Other car brands do this as well.aft981 wrote:It's the way Infiniti's are set up. Same with Nissans. The Murano I had before my EX was the same way.
I believe the main reason they do this is if you have re-circulated air on (especially if it's cool or damp outside) then the inside air that you're breathing in and out gets damp, so without a/c on (which removes moisture from air) the air inside the car would get more and more moist, and would steam up the windows.
Also if you press the front defogger button it automatically turns the a/c on to ensure it's blowing only dry air onto the front screen.
