Taylor_Durdan wrote:...or you can acutally use your exh downpipe if you want (but you get alot of unecessary smoke)
If you use the Exh, wouldn't that create a pressure instead of a vacuum therefore creating more pressure into the engine and an exponential rate?
If you use a catch can on the left side of the motor, or just dump it off, the pressure is able to be relesed at any rate it chooses to do so..
Running the hose back into the turbo could possibly be bad for it.. think of the compressor wheel spinning at X amount of RPM and then blow by, or vaporized oil slams into the fins, goes through the turbo, and down through the intercooler.. at which point in time, somewhere in that line, it's going to gather somewhere, therefore disrupting airflow, and possibly creating a stock of oil in the bottom of the intercooler (hence the reason some intercoolers have drains)
The motor itself creates a vacuum, so it sucks through the breather valve, and is vented through the other side of the valve cover..
Maybe I'm wrong?
