Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Sat Oct 02, 2004 12:46 pm
pcv= positive crankcase ventalator. IT lets pressure out of the crank case. Piston rins cannot seal %100, some pressure wil always seep by into the crank case, if the case was seeled it would pressurize till the unburned air/fule mixture ignited from heat. originaly a vent was added that vented through a filter to catch oil and released preture to the outside air. However the whole emitions thing came around and so a valve was added to alllow venting of the crankcase back into the intake so unburned fuel could be reused to keep emitions down.
