franzman »
https://forums.nicoclub.com/franzman-u254522.html
Sun Nov 22, 2015 5:43 am
Alright I fixed it.
What you need:
Philips screwdriver
Tissue
Steps:
1. Take out glovebox. On the bottom there are two plastic pins that click out, after you can remove the glovebox.
2. Remove the plastic cover around the glovebox. There are 6 screws and a plastic clip next to the top screw, next to the center console. (Top right for right-hand steering, top left for left hand steering)
3. You can now see the blower motor, cooling unit etc. The air mix door motor is next to the center console, a small black box. From underneath you should see the arm that connects the motor and the air mix door.
4. Remove the plug, it's a clip so you have to push the little "nose" from the top.
5. Loosen the 2 screws holding the metal braket.
6. Wiggle out the motor without braking any plastics...
7. Now you can replace the whole motor or you do as I did and open the thing up ( remove the metal braket and open the box.
8. For me there was grease all over the copper sliding contacts which I guess was the problem. I removed all excessive grease.
9. To reassemble take the bottom half with the motor, one gear and encoder (blue thing with 3 pins) and the top half with the half-gear and 2more gears. Putting it back together takes some patience but it can only fit one way;-)
10. Plug in connector and test function: start engine and hold "off" on the ac until all the lights and display come on. With the temp dial, dial up to "4" and by pressing "defrost" go through all the modes 41-46. The motor should move accordingly.
11. Put everything back together in reverse order. Especially putting the motor back in place is a bit annoying.
I hope that helps some people. Will add pics later on:)
